Put the Sonic back on the dyno tonight. I'm currently developing parts that I intend to sell, and have been doing a good bit of testing at each stage. All of the parts are prototypes at the moment, and I'm not sure if I'll offer all of them yet.
Currents mods:
Intake system
Aluminum intercooler hard pipes
Ported intake manifold
3" 304SS catless downpipe.
3" 304SS midpipe with 100cel catalytic converter
3" 304SS cat-back with two magnaflow mufflers
Trifecta "Full" tune right outta the box
93octane
The car was run on my the local Mustang Dyno. This dyno reads 8% LESS than the typicall DJ dyno. I have verified this on a local DJ dyno a couple months ago. I intend to put it back on another local DJ again for direct comparison.
WHP = Blue
WTQ = Black
AFR = Red
BOOST = Green
These numbers work out to 188whp and 231wtq on the local DJ I've used for comparison.
Based on the last couple times I put the car on the dyno, it appears I'm at some sort of ECU imposed HP limit past 4750rpm. If I overlay this graph with the last time I was there 6wks ago pre-3" cat-back (stk cat-back) I found HP and TQ to be virtually the same from 4750 up. I would presume this is a "safety net" that Trifecta has enabled to keep some part of the drivetrain happy or keep the injectors from going static.
Power on this dyno when the car was 100% stk was 120whp and 129wtq. The graphs posted below are with the airbox lid open(+6whp/wtq). I meant to grab the 100%stk graph for comparison, but mistakingly grabbed these instead. Either way you can see how dramatically different the midrange is.
Now to figure out what needs to happen in order to raise the upper RPM power limit so power can keep climbing!
Currents mods:
Intake system
93octane
WHP = Blue
WTQ = Black
AFR = Red
BOOST = Green
