CjCsonic
So just got a fresh order of rotors in at NAPA. And behold Buick Encore rotors come in.....
So I investigate.... same bolt pattern, same hub bore, same height, pretty much all the same except... They are 11.8" and the sonic runs 10.6". Upon further investigation on the Encore system I see it appears the calipers quite possibly are the same except the bracket looks to be a taller/longer mounting height obviously to acomadate the larger rotor.
I'm waiting to hear back from a salvage yard that will be measuring the distance apart on the bracket to spindle mounting points.
If all goes well I do believe we could all do a very basic swap of calipers and rotors and end up with almost an inch larger front brake setup.
I can't seem to get a part number for the spindle itself from the Encore but can for the sonic otherwise if they matched then I would say it would be GTG! Already checked the bearings and hubs are the same too.
What does everyone think of this idea? Do you thing GM would make the bracket mounting different to stop any swap possible?
