TurtleOverlord
Long story short, aftermarket headunit, backup camera failed.
I thought I would get the factory camera, because it probably has an appropriate field of view and should stand up to water better. (mine was pointing at the ground and got corroded.)
So I ordered the whole piece above the licence plate.
The problem is the camera has 6 wires
https://images-na.ssl-images-amazon.com/images/I/616BjntD68L._SL1443_.jpg
Does anyone have any idea what these go to?
I found a link https://www.the12volt.com/installbay/forum_posts.asp?tid=120691
But thats obviously not right, because when I connect power from the reverse lights to gray(there is no blue?) the reverse light circuit goes out until I disconnect it.
Maybe someone who works at a dealer can look up some wiring diagrams??????
