Just announced in the 2015 performance catalog. What are your thoughts?
LTG Four-Cylinder Engine: 2.0L Small Block | Chevrolet
MPFab is almost making that 2.0's flywheel power at the wheels with his turbo upgrade and it won't come with the 9 grand engine price and all the headaches and more money that go with making it work in a platform it wasn't designed for.
this is a factory motor that comes with a warranty.
This one note in the warranty information removes the warranty from any engine swapped vehicles. Last I knew any vehicle made since as far back as I can remember would was subject to emissions certification and as such any modification that differs from the stock tested and certified configuration is technically no longer "street legal"
6. Must be installed in a “street legal” automotive application for use on public roads
So $9000+ installation and other associated parts seems a lot higher than what it would cost to build an engine to that power level and be reliable.
An engine swap would no longer make it legal though. You would be in violation of the emissions certification. Just because your state does not test does not mean it is legal.![]()
this is false. every where ive lived (texas, illinois, california, washington, and south carolina) engine swaps are 100% legal as long as the engine swapped in meets the emissions specs of the model year car it was put into. so (if someone wanted to pay for it) they could swap a 2014 stingray motor into a 2012 sonic and it be legal because the 2014 emissions laws are the same/higher than 2012's
I don't have testing either, but I still can't tamper with emissions controls without running foul of the state motor vehicle code. They don't test, but can ticket and fine.![]()
Same here but I used to drive a camaro with open headers as a dd, got pulled over plenty never got an emissions ticket. Maybe they are stricter in your area![]()
Anyway back on topic, they list on another page a trans and a couple other things, wonder how much a whole set up would run.
If I die, bury me in my truck, because it's never been in a hole it can't get out of!
