RichieRocket
I have an LT HB, basically because I did not want the leatherette seats or 205/17" wheels tires. The one thing I regretted not getting is a sunroof, not available on the LT ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So I was thinking how about a professionally installed aftermarket sunroof. A simple manually operated sunroof that tilts up or can be removed are $300 installed. I had a manual pop-up sunroof in my '89 Probe GT.
Things that worry me:
- No gutter and drains, seal depends on glass edge compressing the rubber seal evenly all around. They claim if you keep the rubber seal clean, it will seal properly...
- roof is a compound curve, curves fore-aft and side-side, how does the frame grip the bare metal edge? Any chance of corrosion on the roof edge?
- if the glass panel is not flush with the roof, will it make a lot of wind noise?
Anyone have experience with aftermarket sunroofs?
Here's one I found with a quick search:
Aftermarket Sunroof Product Lines
