I don't know if this is the right spot to post this but...
Has anyone installed an alarm and had an issue with the unlock wire? I just installed a crime stopper alarm on my 2015 1.4, manual trans LT sonic, and the alarm will arm and lock the doors but will not unlock on the unlock wire. I have tried
"Power Unlock- brown/white - BCM under driver dash, blue 27 pin plug, pin 15",
"Lock Motor- brown/yellow 5 wire BCM under driver dash, pink 27 pin plug, pin 4"
"Driver Unlock Motor- gray 5 wire BCM under driver dash, pink 27 pin plug, pin 1"
"Passenger Unlock Motor- gray 5 wire BCM under driver dash, pink 27 pin plug, pin 2"
I cant get any of these to unlock any door, the alarm disarms but the doors fail to unlock...
Also after 10 minutes, the car ecm shuts down and triggers the door trigger wire causing the alarm to go off.. I have the door trigger on "GRAY WIRE (-) PINK 27-PIN PLUG, PIN 22 @ BCM" is there an alternate wire I should be looking for?
Any help would be greatly appreciated!
