milesvdustin
I have a 2012 sonic plagued with front end noises. It has the Moog end links and new moog greaseable ball joints. Control arms a year ago,, and they are cheap ones. It is now making a popping sound from the driver side only on bumps big or small. I suspect the front bushing on the control arm, I can see some lateral movement when I torque on the arm with a pry bar.
Do I have to do the entire arm again or can I just swap in new bushings? Seems way cheaper. Any DIY on this? I plan to tackle this after valve cover gasket and timing belt.
Car has 127k miles on it.
Sent from my SM-G986U using Tapatalk
