Import Image Racing? Legit site?
CGturbo
iraqivet
Banned
except they have the model listed as Q-08
"BC Racing BR Series Coilover Kit are the absolute best coilover for the money, hands down.
Features
53mm Dampers (Larger then the Competition)
Fixed Cup/Locking Collar Design (Unlike cheap coilovers, this feature will not change your ride heights, camber, or wear out your tires)
Full Pillowball Mounts in the Front & Rear. (where applicable)
Rubber Inserts built in to keep the noise at a minimum.
30 Levels of Damping Force Adjustment(adjust compression/rebound)
Separate Full Length Height Adjustable
Clicks when you turn the damper handle allowing you can keep track of position
One Year Warranty
Rebuildable
Full set included - 4 coilovers
Also, we offer optional rear extenders, which are a great accessory. They allow you to change the range of dampening without removing your rear seat every time.
BC Racing has the best warranty in the industry. They charge $95 per replacement coilover after the first year.
There is no downtime as you will receive a BRAND NEW replacement coilover in lieu of sending it in for repairs.
Additional Information
Model: Q-08 Manufacturer: BC Racing"
and the sonic ones are T300 i would call and talk to them but still a good price
007CobaltLS
vento
d.p
