I know we share engines with the Cruze, so our our plugs badly gaped from the factory like many/most of the peoples' over on CruzeTalk?
I ask rather than check myself because besides not having the tools for the job, I'm terrible at even simple car work and don't want to screw anything up. I asked the dealer if they would check while my car was being serviced the last time since it's become a widely known problem on the net and they refused unless it threw a code, which this apparently won't.
also, when you're dealing with nitrous and boost. you want a smaller gap due to the seriously higher compression in the combustion chamber. also, you would rather the system get some spark than none and lean out or detonate. definitely dont want any detonation...which is why the 'temperature' of the plug is cooler too.
