SmoothSonic
Yesterday after filling my gas tank, I was driving home and heard a squeaking noise. Got home and found a loud squeaking noise in the area of the serpentine belt. Also, my idle was rough and gradually became rougher while driving. Engine light on. The codes are P1101 and P0507. I think those sensors are going off down the line as a result of something mechanical failing.
The sound decreased when I applied pressure on the gas pedal.
I took it over to my repair shop to help diagnose the problem.
Does it sound like a bearing had blown out?
I've often wondered what else could go wrong before hitting the 80k mark.
The car has reached close to 77k mileage
Some of the things I've replaced on the car already. I should probably list all of them in my signature. Throttle body, valve cover gasket, transmission, clutch, master cylinder (tranny, clutch, and master cylinder: There was a leak in the master cylinder which destroyed everything downstream. warranty covered it), water pump, water tank (it had hairline cracks at 70k mileage), vapor canister purge valve (had a trouble code for it), all 4 tires, intake air filter, low beam headlight bulbs, O2 sensor (rodent chewed wire) and ignition coil pack.
