Preloader
The M32 Martyr
I want to share the formulas I've learned in my search for the best turbo selection for my application. Don't be intimidated, the formulas are easy and most of it is the same because we are staring with the same displacement.
The only variables that will affect the outcome are max RPM you plan to peak at, the RPM you desire to begin creating boost and the PSI of boost you think you will run to achieve the lbs/min of air to meet your power requirements.
Let's start with displacement. There are 16.387cc in a cubic inch.
1364cc/16.387 = 83 CI
Next we calculate the airflow of this displacement at a given RPM in it's naturally aspirated state. I'm gonna use stock "peak" rpm to show the accuracy of this exercise.
(CI x 0.5 x RPM) ÷ 1,728 = CFM
(83 x 0.5 x 5,500) ÷ 1,728 = 132 CFM n/a
Now we have to correct the CFM for volumetric efficiency or VE. 132 is in an ideal world where friction and and valve opening time are not an obstacle. However a modern 4v per cylinder engine with variable valve timing (VVT) has a VE of ~95%.
CFM x 95% = corrected CFM
132 x .95 = 125.4 CFM
Now we get to apply the boost.
Turbo compressor maps have pressure ratio (PR) on the Y-axis. To establish PR you need to plug in the boost PSI you plan to run on your turbo. For this example I'm gonna use the 22psi that is achieved with the Trifecta tune.
(Boost PSI + Atmosphere PSI) ÷ Atmosphere PSI = PR
(22psi +14.7psi) ÷ 14.7psi = 2.5 PR
FYI, 2.5 is a very high PR for the smaller turbo family, which our stock GT14 is kin to.
Next we have to convert PR into Density Ratio (DR). This can be found on a density chart.
As air is compressed it heats up and it's density goes down. For the sake of simplicity we are going to assume the I/C removes all the added heat therefore making the DR the same as the PR....... 2.5
Now we multiply our corrected n/a CFM by our boost density(DR) to get our turbocharged CFM. As a general rule, every 14.5 CFM or 1lbs/min will generate about 10 Horsepower.
Here we go............
CFM x DR = CFM Turbocharged
125.4 x 2.5 = 313.5 CFM
To convert to lbs/min multiply CFM by 0.069
313.5 CFM = 21.63 lbs/min
21.63 x 10hp = 216 HP
Multiply that times a drivetrain loss of 15% and you get 184 whp. Pretty damn close to what people are seeing with a tune and basic mods.
