sx sonic
Just finished a sealed airbox to go with my ZZP intake. I've always been a fan of haveing a sealed aribox around the filter to 1. reduce intake temps and 2. the ability to generate positive pressure in the airbox (Ram air), which i accomplished with a Danny 5 style CAI thru the foglight.
Total cost was about $50 for some Sheet aluminum, rivits and vacuum line for the lid seals.
Temps going down the highway are ambient according to my UG (ambient reading vs intake temp) or 6 degree higher than my radio displayed temp which i've come to suspect is not accurate. Sitting at a stop there is some heat soak but it quickly drops once moveing.
Interestingly but not too suprising is that the ambient temp is subject to heat soak if sitting for while with a hot engine. Takes longer to fluctuate than intake temp but something worth mentioning. Also of note is Intake temps will slowly climb with the throttle fully released, temps quickly drop once the throttles opened back up.
-Tyler
-Tyler
