I know ecomodder.com advocates pizza pans but I want something that will look nice. Both attractive and aerodynamic
Good point, I think I'm going to go down from 205/50R17s to 16" rims with 205/55R16s.Aerodynamic wheels and wider tires are almost counter intuitive... what's the goal here?
If you want to run a more efficient setup, get a smaller, lighter, narrower tire. Wider tires take more energy to turn and have greater wind and rolling resistance.
I have 225/45/17's on my hatch and they fit just fine with stock RS wheels.
Sent from my HTC One_M8 using Tapatalk
Really you want as thin and tall a tire as possible
Not necessarily.
You want to stay as close to the stock tire height as possible. A taller tire will change the effective gear ratio of the car causing the engine to work harder to get the car moving - which will use more fuel.
The factory has to meet Corporate Average Fuel Economy (CAFE) standards, so they optimize the cars to provide the best fuel economy based on the gearing and tire sizes they select as standard equipment.
Our engines are small - forcing them to work harder by effectively giving the car a taller final drive ratio will reduce fuel economy in almost every case.
Not only that, but you will end up with a speedometer and odometer error that will prevent you from knowing what your actual fuel economy is (speedometer and odometer will read lower than actual speed/mileage).
A taller thinner tire will be more efficient than non
But yea basically just go thinner while keeping stock hight
So which is it?
First you say a taller thinner tire, then you say thinner while keeping stock height.
Those are two different things....![]()
This is what I'm considering right now, Ronal Aero BPS:
The tire I am interested in is the Michelin Energy Saver A/S and I can get it in 205/55R16 or 215/50R17A 205 tire is the same width whether it is on a 16" or a 17" rim.
There may be a slight difference (a pound, maybe 2) in the actual weight of the tire, based on 16 or 17" rim.
It would make more sense to look for a Low Rolling Resistance (LRR) tire if your goal is to increase mileage.
A good quality LRR tire with the lightest weight, mounted on the lightest wheel will save more fuel than any "aerodynamic" wheel will.
The stock 15" wheels take a 185/65/15 I believe. I'd go back down to that if I was interested in fuel mileage. Instead i'm running RS wheels with a wider than stock tire, because I want the car to handle and stop better and can pay a little more for gas without worry.
