sonic007
This is a bunch of wiring locations and polarity from my work. We use the site called Directechs here in our bay. Also incuded speakere sizes and depths
12 Volts- red/yellow (30A) + BCM under driver dash, white 26 pin plug, pin 2
Second 12 Volts- red/brown (30A) + BCM under driver dash, white 26 pin plug, pin 3
Starter- yellow (for starter kill only) + starter or underhood fuse box, black 42 pin plug (X3), pin A2
Second Starter- wht/pur (r-code); wht/blk (5V ref) (Tech Doc 1605) +9.6K ohms ignition sw or BCM under driver dash, grn 25 pin plug, pins 15, 22
Ignition- purple/black + ignition sw or BCM under driver dash, green 25 pin plug, pin 6
Accessory- purple/yellow + ignition sw or BCM under driver dash, green 25 pin plug, pin 5
Second Accessory- (same as second starter) +6.3K ohms
Keysense- (same as second starter)
Data Bus- green/purple (immobilizer LIN bus) data immobilizer module or BCM under driver dash, grn 25 pin plug, pin 2
Can Bus High- blue (high speed GMLAN) data data link connector or BCM under driv dash, blue 27 pin plug, pin 24
Can Bus Low- white (high speed GMLAN) data data link connector or BCM under driv dash, blue 27 pin plug, pin 23
Can Bus Sw- green (low speed GMLAN) data data link connector or BCM under driv dash, blue 27 pin plug, pin 22
Power Lock- brown/yellow - door lock sw or BCM under driver dash, blue 27 pin plug, pin 19
Power Unlock- brown/white - door lock sw or BCM under driver dash, blue 27 pin plug, pin 15
Lock Motor- brown/yellow 5 wire BCM under driver dash, pink 27 pin plug, pin 4
Driver Unlock Motor- gray 5 wire BCM under driver dash, pink 27 pin plug, pin 1
Passenger Unlock Motor- gray 5 wire BCM under driver dash, pink 27 pin plug, pin 2
Parking Lights (-)- green/gray - headlight sw or BCM under driver dash, white 26 pin plug, pin 22
Parking Lights (+)- purple/gray (L); gray/brown (R) + BCM under driver dash, black 26 pin plug, pins 6, 5
Hazards green/white - hazard switch or BCM under driver dash, blue 27 pin plug, pin 26
Turn Signal (Left)- blue/white (F); blue/white (R) + BCM under driver dash, brown 26 pin plug, pins 2, 1
Turn Signal (Right)- green/purple (F); blue/purple (R) + BCM under driver dash, black 26 pin plug, pins 3, 4
Headlight white/purple - headlight sw or BCM under driver dash, white 26 pin plug, pin 16
AutoLights- green/brown (ground to turn off autolights) - headlight switch or BCM, white 26 pin plug, pin 11
Reverse Light- green/white + BCM under driver dash, gray 26 pin plug, pin 3
Left Front Door Trigger- gray (xpress down wndw); gray(xpress up/down wndw) - BCM, pink 27 pin plug, pin 22; driv wndw mtr, blk 7 pin plg, pin 6
Right Front Door Trigger- gray - BCM under driver dash, pink 27 pin plug, pin 13
Left Rear Door Trigger- gray - BCM under driver dash, pink 27 pin plug, pin 27
Right Rear Door Trigger - gray - BCM under driver dash, gray 26 pin plug, pin 11
Dome Supervision- gray + BCM under driver dash, gray 26 pin plug, pin 1
Trunk/Hatch Pin- purple/gray - BCM under driver dash, pink 27 pin plug, pin 5
Hood Pin- brown/green - BCM under driver dash, black 26 pin plug, pin 24
Trunk/Hatch Release- yellow/blue (rear handle switch) - BCM under driver dash, pink 27 pin plug, pin 15
Trunk Release Motor- green/brown or gray/yellow + BCM under driver dash, black 26 pin plug, pin 12
Fuel Door Release- (locks/unlocks along with doors)
Factory Alarm Arm- (arms on lock with door open)
Factory Alarm Disarm- (see disarm no unlock)
Disarm No Unlock- (Passkey and ignition)
Tachometer- NOT blue/white or pink/black ac any fuel injector
Clutch Pedal- yellow or blue/yellow (see Tech Doc 10001) resistor clutch switch, black 3 pin plug, pin B
Fuel Pump- gray or purple/gray + underhood fuse box, blk 75 pin plg (X2), pin H7,G5
Rear Defroster- blue/white - BCM under driver dash, gray 26 pin plug, pin 24
Mirror Defroster- (same as rear defroster)
Left Front Heated Seat- (low speed GMLAN)
Right Front Heated Seat- (low speed GMLAN)
Speed Sense- (wheel speed sensor)
Brake Wire- brown/yellow + BCM under driver dash, black 26 pin plug, pin 11
Parking Brake- blue/purple - parking brk sw or BCM under driver dash, gray 26 pin plug, pin 15
Horn Trigger- green/white to brown/white - horn switch or BCM under driver dash, brown 26 pin plug, pin 19
Wipers- gray + BCM under driver dash, black 26 pin plug, pin 16
Left Front Window- (Up/Down) (motor is part of module)
Right Front Window- (Up/Down) yellow/black - brown/yellow A driver kick, door harness
Left Rear Window- (Up/Down) green/gray - brown/blue A driver kick, door harness
Right Rear Window- (Up/Down) green/gray - brown/blue A driver kick, door harness
Sun Roof (Open/Close)- green/white - blue/white (funct with ign on only) + sunroof switch, black 4 pin plug, pins 2 - 3
Radio 12V- red/blue + radio, black 44 pin plug, pin 44
Radio Ground- black - radio, black 44 pin plug, pin 38
Radio Ignition- (low speed GMLAN)
Radio Illumination- N/A
Factory Amp Turn-on- N/A
Power Antenna- N/A
Left Front Speaker (+/-)- blue - brown/blue +,- radio, black 44 pin plug, pins 40 - 32
Right Front Speaker (+/-)- yellow - yellow/black +,- radio, black 44 pin plug, pins 39 - 31
Left Rear Speaker (+/-)- green - green/black +,- radio, black 44 pin plug, pins 42 - 34
Right Rear Speaker (+/-)- white - blue/black +,- radio, black 44 pin plug, pins 41 - 33
Aux. Audio Input Left (+/-)- gray - brown +,- radio, black 44 pin plug, pins 24 - 23
Aux. Audio Input Right (+/-)- green - brown +,- radio, black 44 pin plug, pins 10 - 23
SPEAKER SIZES AND DEPTH
Left Front Speaker 6.5 3.5 left front door
Left Front Tweeter 1 left front pillar
Right Front Speaker 6.5 3.5 right front door
Right Front Tweeter 1 right front pillar
Left Rear Speaker 6.5 3 left rear door
Right Rear Speaker 6.5 3 right rear door
Also have a few schematics for bypassing the clutch and other remote start diagrams.
#1
#2
#3
Power Antenna- N/A
#1
#2
#3
