SouthFLSonic
Goood yea the full spectrum sprays wayyyy better than the blaze. Its a bit thicker if you will. It will cover alot better.
Yeah the Blaze colors look the best but fade fast, spray like crap and clog the nozzle bad. I found out about putting the can in a bucket of hot water when using the Blaze because it helps thin it out and make more uniform for spraying. I also found out that if you get a rough dip you can smooth it out with Naphtha and spray right over it because the Blaze orange was so rough I almost peeled down to nothing to fix it.
