I am considering new wheels and tires. I really like what D'Wolf and MPFab did and I think I may go down that road except with 8.5" rims instead. So with 8.5" rims et 35 or 42 and 235-40 R18 I get the following info (compared to OEM)....
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
et 35:
Package 2 is 16 mm (0.6'') closer to suspension/brakes components. Make sure that you have enough room for that. If not, consider lower offset, narrower tires or using spacers.
Fenders clearance:
Package 2 will stick out 24 mm (0.9'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells clearance:
Will fill out the wheelwell by extra 5 mm. Acceptable for most cars.
et 42:
Suspension clearance:
Package 2 is 23 mm (0.9'') closer to suspension/brakes components. Make sure that you have enough room for that. If not, consider lower offset, narrower tires or using spacers.
Fenders clearance:
Package 2 will stick out 17 mm (0.7'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Will either of these set-ups clear an all oem set up besides eibach's Front 1.2"drop - Rear 1.4" drop?
