Well then I guess I will adhere to the OP. When I had that blowout yesterday and had to put on my donut. I sure whisked those lugnuts off and didnt even step on the wrench for leverage. If thats 100 lb ft. Then its not tight enough. You should NEVER be able to remove a lugnut without stepping hard on the lugwrench for leverage, and maybe a good grunt too.
I didnt try any other lugs on the Sonic, but these tires was just rotated just a couple weeks ago at GM. (yes maybe they didnt use a torque wrench, or to the proper torque). Either way the nuts on that wheel was too loose if you can throw the cheap lugwrench (that came with the car) and just break them loose with very little pressure.
If you would read my post completely you would see that I know WHY you dont overtighten the lugnuts). I wasnt trying to tell you to overtighten. I was saying that too loose is still too loose). I have likely changed more tires than you have even seen with my years of race cars.
Have you ever had new tires installed and felt wobble (or shimmy) in the steering wheel? Well I have, every time I had tires installed or rotated on my old AVEO. Then I would grab the ol 4 way, tighten the lugnuts a bit, no more shimmy.
The only thing I was really saying is YES you can do LOTS of damage by overtightening, but sometimes maybe the specified torque isnt quite enough. Maybe just bit more would be better and still not be overtight. Stop trying to fight me youngins. Ive been around a while.
