kyleanderson1992
I have a 13 LTZ with the 1.4. I have had a continuous coolant loss and smoke from the tail pipe. I have replaced the head gasket along with timing chain. I have rechecked the block with a block tester and it has passed but I'm still losing coolant out the back. I looked at the turbo when I did the head gasket and I did not see a crack along the wastegate. But I did find I have cylinders two and three spark plugs fouling out with coolant. Do I really have another bad head gasket or could I maybe have a bad turbo? When I bought the car, I was told the turbo was newer but I also do get a intermittent PO299. I have done all the typical 1.4 repairs like the water outlet and intake manifold and valve cover.
