krakenredbeard
How Rosie Currently sits:
Day of Purchase March 25, 2014
Me and my sale rep Ronald Starr of West Chevrolet
So this will be the start of my build thread.
Done:
De-badged the rear
2m/70cm ham radio installed
15% tint/droptint 70% down the windshield
DDM Works shifter bushings
Bypass the bypass
No pictures
MTech m32 short throw
Ultra Gauge
DDM Works intake powder coated red
14 Chevy Sonic RS DDM Works intake - YouTube
ZZP turbo back exhaust w/ secondary cat and muffler
Forged atmospheric BOV
size comparison to a greddy type s
RS Badge Relocation
Trifecta full tune
Video So Far testing out a dash cam kinda low quality but will work
https://www.youtube.com/watch?v=fAQB01XAPkU
Duplicolor Red brake calipers
Full super bright LED conversion inside and out with the exception of hi and low and fogs
Phillips hir hi beams
Phillips vision plus low beams
Superbrightled full led conversion 14 chevy sonic rs - YouTube
Comparison of led to stock
Led vs stock lighting 14 chevy sonic rs - YouTube
Painted heat shield Duplicolor Engine Enamel Red
Paint DDM Heat Shield Duplicolor Engine Enamel Black
Rear Fog light
Sharp Payne ported intake manifold
DDM Coil Cover powder coated red
Black vinyl bow ties
Blacked out door trim chrome
Blacked out lift gate chrome
Rear pocket that wasn't useful, but is now:
I made a thing (and you can too!!!) I made a thing (and you can too!!!) - Chevy Sonic Owners Forum
Redline tuning ELITE hood struts
https://www.youtube.com/watch?v=F-6XifCJKWE
Newest Video Sounds of a modified Chevy Sonic
https://www.youtube.com/watch?v=KU4HH1r1EXk
TurboTechRacing lower trans and upper motor mounts
Uninstalled
Installed
Hella Super Tones
shows relay and wiring
Comparison of Stock to Hella Super Tones
https://www.youtube.com/watch?v=O0_M8TSpbCg
Lock alert & Alarm Hella Super Tones
https://www.youtube.com/watch?v=-girDKIjp1Q
MPFAB FMIC Upgrade Kit
Turbo Hot Side Charge Pipe
Hot Side to IC
Cold Side from IC
Cold Side OEM upper Charge Pipe to TB
RS Bumper foglight needs to be Shaved to fit
Overall was impressed with the quality of the kit, We did have to add a washer to the FMIC supports so that it cleared the crash bar, and didn't rub the old fmic supports, and also having to shave the fog lights a bit, but with anything custom comes issues.
Torque Solutions Delrin shift knob 10x1.25
In order to make this work we had to use a strap wrench to get the old pressed on knob off. You then will need to use a tap and dye set and we used a 12x1.75 to start and threaded it down to remove the knurling. Then we threaded it down another step to the actual knob size 10x1.25.
We then had to modify the lockout boot and the spring to make it all work. I know it doesn't look different but when you get the stock knob off you'll see what I mean.
Plans:
#42 injectors
Lock Knob Delete
Moog Endlinks
DDM rear brace
ZZP Lower Control Arms
Peddlers coil-overs \ BC Racing coil-overs
Euro Spec Headlights & Taillights
Passenger Seat Cubby
First Aid Kit
Holden Barina RS Front Bumper
Camaro rear view mirror
I want to run extremely light weight 15x7 wheels with meaty tires. Enkei rpf1 or Volk te37 gram lights. Not sure yet. I am shooting for under 10lb per wheel but would settle for less than 15lbs if I had too. I know the lug pattern is stupid so may have to use some adapters to get me a 5x114.3 to get lighter wheels and more options.
I want to fully de-chrome the car.
I'd also like to do the Seibon carbon hood with the slits and the carbon hatch but i do ham radio so if I get rid of the metal hatch I'll have to relocated my antenna, and I like its current location.
A lot still in the planning phases I'll update with pictures and info as stuff changes. Any ideas/criticisms are welcome just be tactful and respectful.
Albums:
May 2014
June 2014
July 2014
Done:
De-badged the rear
Bypass the bypass
No pictures
Ultra Gauge
No Longer on the car, See MPFAB FMIC
DDM works full charge kit powder coated red
DDM Silicone full charge kit:
RS Badge Relocation
Trifecta full tune
Rear Fog light
Uninstalled
Installed
Hella Super Tones
Hot Side to IC
Cold Side from IC
Plans:
#42 injectors
Lock Knob Delete
Moog Endlinks
DDM rear brace
First Aid Kit
Albums:
May 2014
June 2014
July 2014
