This mod will work for the hatchback only, as it takes a 921 bulb.
I use a Philips 50W 12V halogen bulb (Philips P/N 14730) from Home Depot. It's in the lightbulb section. These are rated at 850 lumens each. They are VERY bright for a reverse light. And cheap too.
Philips website link for these bulbs
Yes, 50W each is a lot for the wiring/housing to take. I've run these in several different cars for years though with no problems, as I don't ever have my reverse lights on for longer than a few minutes.
To install, spread the pins apart on the bulb just a bit. Take some needle nose pliers and squeeze the prongs in the bulb connector on the car together to make for a tighter fit. Install as if replacing the bulb normally.
