aaronalde8
I keep hearing an occasional member saying he pulled his ABS fuse. What is this and what does pulling it out do? help would be appreciated.
the worst part about holding it down to disable it is that it doesn't fully disable it! I got tired of it kicking in after I shut it off and pulled the fuse. This is my first car with ABS and it never kicked in before I pulled the fuse so I wont miss it one bit.
I've been hitting the traction control button. So far it's resolved the issue with the car being slowed to a crawl on fast starts, so it does indeed seem to disable the major annoyances for me. ABS gets to stay on.
It's come on a few times when supposedly "off", unless the rev limiter on the 1.8 is set to 4500...
From what I understand, the button will disable the brake-based aspect of TC but the computer can still cut engine power under certain circumstances if the sensors indicate traction loss. Pulling the fuse gets rid of it entirely. Someone correct me if I'm wrong.
it has never backed the power off with the tc
