cheetahcat79
Hi all, I signed up here years ago but haven't been very active (sorry about that.). I wanted to get some input from more knowledgeable people about a problem I'm having. (2013 Sonic LT, 1.8L)
I went to start my car the other day and got nothing but clicks. When I had someone jump it for me it started right up. Once it's running, it stays running, but if it sits that's when I seem to have problems, like the battery is discharging.
I took it to Advance Auto and had the battery tested, assuming that was the problem, but the battery tested good and so did the starter, but the alternator was putting out high voltage, indicating a bad voltage regulator.
Does that sound like something that would cause my problem? Will a bad voltage regulator cause the battery to discharge the longer it sits (like overnight? It starts up again if I start it shortly after shutting it off)
I'm just looking for feedback, because I'm having someone replace the alternator for me and I don't want to go replacing one thing only to have it be something else. Will a bad battery cell cause the alternator to run too high of a voltage?
Thanks in advance and sorry for the ramble.
