Well I got it all bolted up last night and it sounds awesome.. Here's my setup
- MPFab Intake
- Anaconda downpipe, midpipe and high flow cat
- ZZP cat back with muffler
I had bought the heavy duty v-band clamp from MPFab too but I couldn't get the oil line out of the way to get it on properly so I ran with the stock one. I'll revisit that later. I'm sore as crap today. (broke my neck and back in the service so manual labor and I don't get along very well)
I still have the Trifecta Tune to put in place and I have a short throw shifter I'm going to save for another day.
Besides that middle hidden bolt that was a pita to get the only other really difficult task was trying to hold the pipe and get the clamp in place. I ended up having to call a friend over for a couple minutes to help me with that.
The upper O2 sensor was a sinch to remove from the plug, unscrew and lay to the side. The lower one was much more difficult. I never could get it unplugged so I just had to thread it out of the pipe which twist the line and when I went to put it back in I twisted it the opposite direction, put it in place and threaded it in so it had little to no twist in it when it was in all the way. Hoping I didn't hurt anything but I was tried, hurting and frustrated by this point so it's the only thing I could do.
If I had to nitpick about the things I don't like about my setup it would be the rotation of the muffler the oval is vertical so it seems like it hangs lower than it should and I don't like the exhaust tip. I will be removing that and replacing it with a turn down at some point. I'm going to see if I can rotate the muffler to tuck it under the car more. The dealership installed it for me when they replaced my timing chain. They messed up something in my stock exhaust and wanted to keep it another week while they ordered a factory one. I told them I had a complete cat back in my garage waiting to be installed and they agreed to install it. Its' possible the tech just didn't rotate it enough.
All in all though I'm very happy with it, it sounds great it definitely passes the butt dyno tests.
