I’ve had some oil underneath the car now (leftside looking from front) all over the the oil pan and such. I have replaced my valve cover gasket (again) I changed the oil cooler seals, I did notice oil on the small lip/ring around the center of the actuator so I changed both intake and exhaust seals (inside gaskets). I’m still seeing it in that spot and it’s leaving the car at a decent rate.. could the actuator itself be bad and oil leaking through? The only other two things I could think of on that side are the oil pan isn’t sealed well on that side or my front engine cover gasket which I damn sure hope it isn’t. Just wondering if these actuators can be no good and leak?
