Supervette64
I have an RS hatch with the ZZP rear "sway bar" (which did help the balance of the car quite a bit), and the body roll is still just way too much for my preference.
I've looked at all the aftermarket spring choices (eibach, H&R, B&G, etc) and from the ones that specify spring rates, they're all not much more than stock. They seem to be more focused more on lowering and ride comfort than improving handling dynamics. (I've got nothing against that, its just not what I'm after).
Anyway, some spring manufacturers list all of their spring specs and I'm curious if I can find a spring that fits the sonic's geometric requirements with very little to no modification.
Here's an example from moog: http://www.moogproblemsolver.com/moog/wp-content/uploads/2012/08/MOOG_Coil_Springs_Spec.pdf
Is it as ideal as a performance spring purpose designed from a spring manufacturer for the Sonic? probably not. Can I get a stiffer spring that will fit and compress to a reasonably close ride height? I hope so...
So if anyone has replaced their springs and still have their stock ones laying around, could you let me know what the outer and inner diameter is, spring coil diameter, and free standing height?
Also, does anyone know the approximate weight distribution of the hatch? (Or even better has anyone weighed a RS manual hatch?)
