ReeseLightning
Type Powertrain -----Auxiliary Emission Controls - ISO/SAE Controlled
Description ---Catalyst System Low Efficiency Conditions
Location ----Bank 1
Cause ----No PCM codes set, ECT input over 167°F, IAT input over O°F, MAF input 12-32 g/sec, engine speed below 4000 rpm, engine load under 63% and steady for 4 minutes, then engine speed at 1000-3000 rpm and VSS at 30-75 mph and the PCM detected that the catalyst O2 storage capacity was below an acceptable level
Installed the Anaconda and had a few codes thrown, it's been cold out and idk if the ecu needs to relearn after this exhaust is installed or I need to fix something. Any info would be appriciated.
Location ----Bank 1
