Charly1979
My chevy sonic 2012 1.8 Lt has an issue i don't know what's. It first started with an issue with the selenoids codes ( p0700 and p0796) the first time , after that car wouldn't drive faster then 15 miles per hour. All I did was to change transmission oil and clean selenoids, cause I could not afford to pay a mechanic or by the selenoids pack , the worst part is that not even the chevy company itself doesn't sell those anymore ..
Car was driveable again after changing just the transmission oil but it struggle when you start driving , then it happen again same situation car wouldn't change gears , I bought the selenoids pack from China and I also put both speed sensors ,but car is not moving at all , and this two new codes cane out ( p0700 and p2534) ignition switch Run / start position circuit low .. i put a new ignition switch but that didn't change anything, i also check the fuses that deal with the transmission but seen to work , those anyone know what could be the problem?
