Just wondering if anyone else has had problems with the head cracking on the sonic? I am in the works changing the head due to it cracking through the water jacket and spraying on the spark plugs at cylinder 3 and 4. I installed a refurbed head from autozone and have had nothing but problems. 1. The cams were in backward (exhaust was in the intake and vice versa). 2. After I got it running the oil plugs directly above the thermostat housing were both leaking. Had to pull the plugs and Teflon tape them, that worked. 3. After running for a while I pulled the ignition module and found the #2 spark plug well had antifreeze in it. Sure enough it is cracked at the #2 plug water jacket. I am attaching pics of how I leak checked that.
Sent from my LM-G710VM using Tapatalk
