LS1notFOUND
Discovered this by accident and thought it was pretty nifty on the designers part.
In the event that you want to lock your door and not reach inside and hit the center mounted button or you've already tucked away your keys etc, you can simply use the manual door lock on the drivers side.
When manually locked/pushed down, this will trigger all the others to also move to the locked position and the vehicle chimes 3 times.
....neat!
....neat!
