new sonic owner, previous aveo5 owner.
picked up a 2013 LS Hatchback with 142k on the clock a few weeks ago, fuel saver for work. lucked out with a southern car - aint seen a near 10 yr old vehicle with so little rust on it... not used to that up here in michigan.
will be checking in on and off for tips and tricks.
worked thru must of the regular maintenance stuff so far - oil/filter, timing belt, water pump, tune-up, coilpack (the one in this one was just... ugh). needed a rear hub assembly & alternator. also had the rad fan take an amber herd on me last week (supprise!).
also did a trans flush to get rid of a little bit of accelleration shudder. i dont know why they say not to mess with the fluid on these things. its got a dang drain plug... change the fluid! had some of the uglistest trans fluid ive ever seen that wasnt full of man glitter anyway! yikes!
look forward to getting any advice and knowledge i can out of here.
