mcanderson0
If you’ve pulled your cowl off and looked at the cup at the top of your front struts, you may have noticed it holds water. This is even worse if you have aftermarket coilovers bc your damping adjustment screw is all rusty. Or when you swap coilovers, the top nut is all rusted to the shaft. That sucks.
![EF61BA44-0D19-405C-AA9C-FB46806168DC.jpg EF61BA44-0D19-405C-AA9C-FB46806168DC.jpg](http://www.sonicownersforum.com/forum/data/attachments/12/12233-8441f99799bcaab1f605a48c07ed551a.jpg)
Evanscoatings(dot)com. Type II coating called B-52. Heat it on a hotplate to 350degF, use masking tape to create a form to prevent the liquid plastic from leaking everywhere, and pour the melted coating into the form. Remove the tape after about an hour.
![43080C10-B78D-4102-A1B2-C784343B3F46.jpg 43080C10-B78D-4102-A1B2-C784343B3F46.jpg](http://www.sonicownersforum.com/forum/data/attachments/12/12234-bc39579b1406fa1a4f2d4eca277fab6d.jpg)
Bam, now you have a water-resistant removable plastic plug that repels water from your upper strut cup.
![631BB9C7-D2D6-444C-9511-411CD83D2495.jpg 631BB9C7-D2D6-444C-9511-411CD83D2495.jpg](http://www.sonicownersforum.com/forum/data/attachments/12/12235-1ba11b8d5bd0209453b033f271c4a110.jpg)
