alexanderLTZ
Greetings all, I'm hoping to get some advice here.
I've got a problem with the rear driver's side window on my 2014 Sonic Turbo LTZ. I'll explain and hope someone here can help me get going in the right direction.
A few weeks ago, I lowered the rear windows from the driver's door controls. When I tried to raise them, only the passenger's side window went up. I tried from the rear door control as well and it was still not going back up. After pressing the up button on both the front and back door switch numerous times it finally raised. I decided to just turn the child lock on and not lower it for a while. Unfortunately I was a dummy and pressed the wrong switch the other day when I was going to lower the front window. Now it is stuck halfway down and will not raise. I have tried both switches numerous times and tried different techniques such as holding the switch up while starting the car, etc. I even removed the door panel and checked the connection of the wires to the switch (disconnected and re-connected it) but it is just stuck. It will still go down, but never up.
Has anyone had this issue? I'm moderately mechanically inclined, so should I try to replace the regulator itself? I'm not under warranty anymore (I don't think, I just passed 50k miles). If it's more likely a wiring issue I wouldn't be able to do much myself except replace the switches themselves, but I doubt they both stopped working on the same day, in the same direction.
Any thoughts?
Any thoughts?
