TryingToLearn
Hope this is the right forum: Driver's side front lights are funky. Low beam is VERY low when on. Turn high beams on and neither is on. Turn signal sometimes works, sometimes not. All other lights on car are fine. Suspected shorted bulb. Tested all for continuity and no issues. Switched 3 bulbs from drivers to passenger side. Issue did not change - stayed on driver's side. Forum research turn up possibility of ground or switch issue. Where does one start to find this kind of issue and how is it done? Any help greatly appreciated.
