seems my rad fan only runs low speed sitting in rush hour traffic in 100 degree weather with AC cranked.. which when sitting to long ac starts to warm up... freon is fine aswell as tested, and they noted same with the rad fan ..
when sitting still fan kicks in with ac but airflow dosent seem much but enough that its moving, and it is quiet..
Anyway to test the fan high speed circuit, or away to wire it or set it up to run highspeed only? or should i just remove OEM and place aftermarket with its own controls and relay's that trigger off the low speed circuit?
Prefered to get this done without having dang CEL on..
