JTee2017
Well-known member
Here are some pics and parts used for an alternate hood lift mod.
You will need metric socket, open end, and maybe box end wrenches to install these.
I purchased the struts and brackets from Lift Support Depot. The Ball Studs are mounted by replacing the forward fender 10mm M6 bolt/washer combo and needs to have an M6 thread (not the more common 5/16 SAE thread). So I bought those from Napa, but also Amazon and Ebay has some for about $4 to $8 a pair.
Also, there are several hood brackets that may work from Lift Support Depot or even on Amazon or Ebay. But most will need to have the one hole drilled out to 3/8" in order to fit over the stock hood bolt used to fasten the bracket to the hood.
Here are the Lift Support Depot parts I bought:
2ea - Struts SKU SE180P30 $29.80
2ea - Ball Stud Bracket SKU h-ab115rb $9.00
2ea - 10mm M6 thread Ball Studs Napa 735-3608 (about $6 with dealer wholesale - cheaper elsewhere)
2ea - 5/8" or 3/4" thin fender washer (painted black) for under the ball stud to do this proper. About $0.50 at Ace Hardware.
Any of these should work here for the 10mm M6 Ball Stud and less than factory struts prices - - -
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.X10mm+M6+ball+stud.TRS0&_nkw=10mm+M6+ball+stud&_sacat=0
I recommend this one since the threaded part is about as long as the stock fender bolt you will remove:
https://www.ebay.com/itm/Long-Shank-M6-x-1-0-Custom-Rat-Hot-Rod-Linkage-10mm-Ball-Stud-Small-Pin-Bolt/370994260511?hash=item5660fb2a1f:g:GlkAAOxyVLNS4~b4&vxp=mtr
These should also work .. . cheaper, but you can go into business selling them for $5.00 a pair shipped. . . I guess.
https://www.ebay.com/itm/New-Zinc-Plated-10MM-Ball-Stud-RV-Marine-Boat-Strut-Shock-Mount-M6x1-00-Thread/192086549661?hash=item2cb940249d:g:IucAAOSwNnRYh9xq&vxp=mtr
