I have a bunch of intake related codes I replaced the MAF check engine light went away brought it to a shop to install need radiator fan about 2 hours after picking it up engine light came back with same codes so I replaced the MAP and codes went away for a half hour then came back and when I first start my car is fine but after a hour or so it has though idle really bad acceleration its a Chevy Sonic 1.4 turbo 2017 with ZZP intake. Any suggestions as to what is causing this?
Codes:
P0097
Intake Air Temperature Sensor 2 Circuit Low Bank 1
P0099
Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic Bank 1
P00F4
Humidity Sensor Circuit Low
P00F6
Humidity Sensor Circuit Intermittent/Erratic
P0114
Intake Air Temperature Sensor 1 Circuit Intermittent Bank 1
P2199
Intake Air Temperature Sensor 1/2 Correlation
P2230
Barometric Pressure Sensor "A" Circuit Intermittent/Erratic
Codes:
P0097
P0099
P00F4
P00F6
P0114
P2199
P2230
