Turbonic
as the title suggests, Im noticing a bad noise whenever I accelerate from a stop while making left turns only. it also makes this noise if I accelerate hard in a straight line. I've seen other posts similar to mine but without answers on other websites, it must be a front wheel drive thing. I can also feel this through the steering wheel. It doesn't make this noise when im coasting or on the brakes, only while under engine load
for the record, this seems to have only been occurring since I had the clutch and flywheel replaced. the CV axles are new with about 5k miles on them, the correct amount of transmission fluid is used with the correct type
