Thanks preloader. 2mm Poke won't be anything to worry about. I wasn't worried about the rear wheels as it appears the rear fenders flare a little more. The fronts had me a little worried..
Withing the next year, I plan to do coilovers, had them on my Cruze and loved them. 3in drop with dampers at Full hard, and 20mm of Preload when 10mm was recommended.
Once coilovers are installed, then I will adjust tire size for the ride height. Right now tho, thought 215/45 as these tires are priced very low, and also a nice wide tire for this little car.
Appreciate your help, i'm good with tire calculations, just not wheels.. Just gotta save the $600 now for the adapters and tires..
The wheels are gunmetal color, so should look real sharp against the Blue Topaz Metallic Sonic!!!
