08Bluesky
33K miles on car, 1.8L Automatic 2013
Check engine light has been coming on, triggering a P0449 Code, Gas tank is ¾ full. I did a "search" on the site – found (2) references to the code. Found lots of information on the “Generic” code on the Web, mostly pertaining to Chevy Tahoe’s.
Could be the Canister – have to lower the Fuel Tank to get to it,
Could be a shorted wire in the harness,
Could be the Vent Valve,
Could be a circuit fuse.
The Car seems to run fine as usual, only odd thing is that when the code has not been cleared, the Remote start will not fire. Seems the code triggers only upon minutes after start-up. Once it’s running and I clear the code with my OBD2, it does not re-trigger while driving.
Still a tad cold here in the Burgh so I’m thinking it can wait for warmer weather….
Any heads-ups / suggestions as to how to isolate the issue would be greatly appreciated.
Thanks in advance,
Joe
Thanks in advance,
Joe
