When installing an aftermarket intake on my 2017 RS I had to remove two bolts on the passenger side engine mount. Top one (green checked 1) came off fine, bottom one (highlighted 2) gave me trouble, so I put some PB blaster and use a breaker bar and I accidentally broke the screw it was on (circled red). In hindsight, I probably should have banged the bolt to break the rust or something, but you live, and you learn.
Anyway, I'm stuck with a broken frame engine mount bolt. I'm not sure if it is fully removable or not. There seems to be a small access hole on the lower right side between the frame and the engine and I can touch the bottom of the bolt.
Does anyone know if this frame bolt is removable or if it's welded to the frame itself?
Side note: car was driving fine afterwards with no noticeable engine raddle, jump, etc. There are two other bolts holding the engine mount in place.
