calebsullivan3
Hey all,
I have been fighting PCV issues for the last few weeks and my patience is wearing thin. To start, I was driving my 2014 Sonic 1.4L Turbo 6spd manual LT (89k miles) to work a few weeks ago when I noticed a very loud whistling noise from the engine bay. Much like the last whistling noise I heard two years ago when I ended up having to replace the valve cover. Being a novice mechanic I figured "same symptom, same fix" so I replaced the valve cover. Not only did the whistle NOT go away, it started smoking out of the tailpipe and idling terribly. A few days into troubleshooting and researching, I noticed a buzzing sound coming on then going off repeatedly from the battery side of the engine bay which I have now determined to be the brake booster pump coming on and off. Didn't think much of it and determined that all my other symptoms must be stemming from issues with the check valve in the intake manifold. I should also note I was getting multiple codes when scanned with an OBD tool. Took off the manifold and orange nipple was gone. Installed the intake manifold mod kit from the CruzeTalk forum and most symptoms went away. No more white smoke and idle is perfect. Car even runs perfectly and has plenty of boost. All I am left with at this point is a chirp in the engine that does not start until after the car has ran for a few minutes sounding like it is coming from one of the pullys, a check engine light, a p0171 code, and the brake booster STILL going on and off constantly every few seconds.
Does anyone have any ideas at all? Please be mindful I am just learning these engines, but my personal (inexperienced) theory was that maybe my main front seal was letting vacuum escape thus my brake booster pump needing to kick on and off to build pressure. In your alls opinion would the main front seal being bad be consistent with the issues I explained above? I should mention that I have driven the car at speeds up to 70mph since repairing the intake manifold and I do not have any issues with brakes at this point.
Any guidance or input is MUCH appreciated!
