Ham_Sammich
Hello, I'm posting because I need a little help. I've been having some issues with my car and took it to the dealership. They called me back and said that my spark plugs are fouled (they said the plugs are white). They want $218 to fix it. I briefly looked online, and it appears a fairly easy fix.
I'm not very car savvy, but can do simple things like swap out air filters and change oil.
Is this possible for me to do without screwing it up?
From what I can see from this thread (http://www.sonicownersforum.com/for...52-help-accessing-spark-plugs-1-4-engine.html)
I need to take the top cover off, remove the Coil Pack, and use a 16mm Spark Plug socket to remove the spark plugs.
I have a very basic set of tools, do I need a socket wrench extension, or anything? It appears I don't from the pictures in the above thread, but just want to make sure.
I've replaced spark plugs on mowers/motorcycles, so I'm aware of the basics of replacing spark plugs. Any other suggestions or advice would be greately appreciated!
Thank you!
Thank you!
