2015 1.8 LT..........when the fan doesn't operate does it also disable the AC.....one more thing I'm only getting 8 volts at the socket relay from the ECM that controls Hi and Lo of the fan with key on engine off.....the constant 12 volt is good too with key on engine off and the ground relay socket is good also when checked with a short finder from ground socket to + at the battery And and vise versa from negative socket to positive at the battery it lights brightly for all tests......both relays click when energized off the car
