Tesseract_Indeed
I've not seen a thread dedicated to Rally Wheels and surrounding discussions, so I thought that I would start one. Firstly...
I am looking at the Method 502 VT-Spec wheels. They are 15x7, +15mm offset, and 5x114.3 bolt pattern. I am currently running stock 16x6 +39mm offset, with awful Michelin Defender 195/65r15 [91T] tires from the dealership. I can make a 5x105 to 5x114.3 adapter work, but I am worried about fender and suspension clearance given the huge offset difference. For height clearance, I have a hell of a lot of room between the tire and fender, even with the mini-van tires.
I want to install Megan Racing lowering springs, which will drop the car 1.1" in front and 1.2" in rear. Given that the new wheels are an inch less in diameter, I doubt actual height clearance will be an issue, even with lowering springs. I emailed Method to see what size tire they recommend with the 502 VT-Spec. My Sonic is my only car, therefore it is my daily driver. That said. I can't buy huge, expensive, short-lived rally tires for it either. I want to combine the rally look (I especially love these wheels) with a reasonable daily driver tire, and make sure it will work with the Megan Racing Lowering Springs.
here are the Method 502 VT-Spec wheels in question:
https://www.methodracewheels.com/collections/rally-wheels/products/mr502-rally-vt-spec
Again, this should start a Rally wheel thread, so the rest of the thread is an open floor for rally wheel discussion! opcorn:
