well here is my write up on how to remove you LAME stock sonic bumper and replace it with some MAD TYTE JDM RS bumper.
part 1 stock bumper removal
step 1. first you need to remove the 10 screws that hold the rear fender liner to the bumper, there are 5 on each side and they are all T-20 torx heads
step 2 remove the two clips that hold the bottom of the bumper to the car. these clips can be a pain in the ass, the best way to get them is to take two flat headed screw drivers place on on each side of the clip and pull out the inner part of the clip to unlock it. then pry the entire clip out
step 3 pull out on the out on the sides of the bumper to un-clip them from the car, then pull back on the center of the bumper to remove it. this part may take some time, as the bumper is cliped into place good and tight . do your best not to break anything!
step 4 admire your work
step 5 have a beer (only if your above the legal drinking age) :banana:
