bullitt4204
I had the wheel weights removed from the factory alloy wheels to prevent corrosion under and around the wheel weights. I had the stick on weights installed inside the surface of the center of the wheel. Once removed, I did have to use clear coat to touch up a couple of small areas where the weight scratched the wheel when originally installed, then when they were removed.
