WyrTwister
Changed the oil on the 2015 1.8l automatic Sonic yesterday afternoon .
After going through the chore of rounding up the correct ratchets & sockets , where is my drain pan ? Quick trip to buy another .
Removed the drain plug & filter / plastic filter " cap ". Re-installed the filter / plastic filter " cap " . Oil finished draining , re-install the drain plug .
Asked Wifey to hunt up a funnel for me . Started re-filling the engine from a 5 qt jug of the second line Mobil 5W-30 full synthetic . With most of the 5 quarts in the engine & funnel still in place , asked Wifey to start the engine .
Engine ran rough & soon died . Checked the oil lever & added a little more . Removed the funnel & re-installed the oil filler cap . Engine restart , engine off , checked oil level . Oil level good .
Only , this time , the engine ran normally . What was different ? ( I figured it out , can you? )
I think the engine holds 4.8 quarts . The remaining oil in the container , I save up and use in my oil can . Seems to work well , but can not tell if it works better than conventional oil , in that application .
God bless
Wyr
God bless
Wyr
