TheGreatAndPowerfulOz
I have been wanting to get my Droid4 suction cup car mount off the windshield and onto the dash, but I couldn't really find anywhere to actually stick the suction cup on without adding a disk to the dash.
Next problem was that the center cup place on the dash has ridges, so a suction cup disk would not mount cleanly into it, so I decided to make a few changes.
I removed the adhesive that came on the disk and then added heavy duty Velcro strips and trimmed them to shape:
The Velcro is thicker than the adhesive that came on the disk, and in two strips, it can mount cleanly to the flat areas and the plastic ridge does not get in the way.
The phone mount can now stick cleanly centered to the dash top:
My next idea is to drill a hole in the dash top just large enough to run the cable through so that there are no cables hanging down over the dash. The cable can then go through another hole and plug into the USB port in the small storage box above the glove box. The red circle shows where I think the hole will go: centered at the rear.
Now I can stream music, use the GPS and have Bluetooth linked calls, all while the phone is neatly out of the way. :banana:
Cliff
Cliff
