venomousranger
I was on Crutchfields website yesterday and when I went to order a Kenwood Navigation head unit, it gave me the option of getting this metra kit for $99.00.
Metra 40-EU55 (met-40eu55) Antenna Adapter Cable for Select 2002- Do I connect the BLUE wire that comes with this adapter to the P. ANT for the power antenna on the back of my Headunit harness? I would think that since the anntenna doesn't go up and down I wouldn't think I'd need to.
Thanks, will do. I hooked up the harness to the Axxcess box and to my vehicle and everything except for the harness to the back of my unit and have the T?C and stability light on my dash....perhaps it needs the headunit hooked up to complete the circuit...or I hooked up something incorrect
For the record, that is the one I bought. I didn't use the blue wire, and it works perfect.
And AFAIK, the T/C and stability don't even pass through the radio, but I could be wrong.
Does anyone have this kit that DID use the blue wire? If you didn't use the blue wire and it work then I will not use the blue wire. As far as amplifier on teh harness the harness is small and doesn't appear to have an amplifier built into it. I guess an extra 12V to the antenna couldn't hurt anything....or could it
