Hello Sonic enthusiasts,
I recently picked up a second Sonic (2015 LT) for the kids - we use our 2013 as a TOAD behind our motorhome.
Although I don't think it's related, I just did the timing belt, water pump, and tranny fluid change on it.
The rear windows, which functioned when I bought it a few weeks ago, have both packed it in - unlikely it is a motor given both sides out. My thinking is either the master switch on the driver door, or a broken wore somewhere. Checked both fuses, and they are fine (actually swapped them front to back to make sure ;-)
Anyone have this experience?
I have also been noticing recently that sometime it wont start on first try - thought at first it may have been the lockout on the shifter, but I think that was coincidence - seems if you try it 3-5 times, it will eventually start up like normal. This is the same thing with autostart - sometimes it wont start remotely (and won't honk when you double-lock) - again, once in the car, you can try 3-5 times and it will go. Once, I actually retried the auto start from a distance a few times, and it did work after 3 tries.....weird.
I would love to hear from others who may have seen other similar issues.
